Old 19-07-2012   #1
Gearbox oil level check
Anyone any suggestions on how to check the oil level in the ZF gearbox for the strada abarth 130tc?
Can't seem to find it in either the haynes manual or the Fiat workshop manual.
I'm kind of guessing I fill it up until it comes out of the filler plug?
Thanks in advance
CaptainJohn2011 is offline Reply With Quote Quote
Old 19-07-2012   #2
Ireland
Re: Gearbox oil level check
ritmos lol a long rusted car of years ago,i remember a 12mm alley on front of box at about half shaft height ,yes fill.
dirtyhands is offline Reply With Quote Quote
Old 23-07-2012   #3
s130 has donated!
As already mentioned.
Front side of box about half way up is a plug.
Place car on level ground. Gently remove plug. Should dribble oil if correctly filled. If it does not then put your little fiinger in the hole and downwards. Can you feel the oil level? If not then topup required.
When filling/topping up I usually just jack the front of the car a little to get the car very slightly nose up. Then fill till oil is level with plug hole.
Strada 130TC boxes are very fussy about oil. Ideally you should use Olio Fiat ZC90 or similar. Do no use and EP / Hypoid oil.
s130 is offline Reply With Quote Quote
Old 28-07-2012   #4
Thanks guys a really great help. I'll take the tip on oil and will probably change the oil fairly soon.
I originally wanted to check the oil as I seemed to be getting a small oil leak from around the selector shaft.
Oil level seems to be Ok so it's definately a very small leak. Anyone had any success curing these kind of leaks on the Strada Abarth ZF gearbox?
Bit bemused, the oil level is fine, there's a rubber seal that goes round the gearbox that also looks fine too.
Old 30-07-2012   #5
s130 has donated!
Can't exactly remember and can't look at the moment but I think you will find that the gear selector shaft is just above oil level so the only oil that gets to the shaft is due to level change on cornering, braking etc. and spray off the cogs.
(T) gearbox oil level. tony_m Fiorino (Mk1 / Mk2) 2 03-07-2008 22:37
(T) Oil level check? warm or cold don777 Barchetta 11 20-05-2008 12:40
(T) punto 1.9 JTD, digital Oil -level check at ignition switch on wesselcolsen Punto (Mk2/2b) 22 14-04-2008 23:07
(G) How to check g/box oil level on 97 Van. Torq Ducato 1 13-12-2006 23:45
