Technical lowering a Ritmo
exylon
Hedmark, Norway
Hi guys..
I want to lower my Fiat Ritmo Abarth alittle in the front, but cant find lowering springs anywhere.. :cry:
Anyone know where I can find it?
Is there any other Fiat that uses the "same" springs as my abarth?
Contact these guys.
http://www.bernimotori.com/abarth_index_en.html
I know they list lowered front springs. So should be able to let you know what is available.
Thanks!
But, I cant seem to find any email adresse.. I live in Norway, and I would love to email them instead of calling them.. :p
would love to know how much they lower my car, and the price ofc..
ABA 2090 Front lowered coil spring. 130 TC - CSA
anyone know their email adresse? :p hehe
Cutting them is an option because the lower / upper coils are against each other an not spaced. The only down side to this is that it is a one way trip.
The other thing to bear in mind when lowering a car is outer driveshaft inclination or dangle.
Ideally the wheel centres/hub nuts should be level with the gearbox differential outputs.
If I remember correctly the normal 130TC has a pretty level straight drive line thought the shafts. Lowering the front will improve handling (understeer & roll), power take-offs (less sit up and beg/rearwards weigth transfer.
However CV joint wear, torque & bump steer will be affected.
Fiat / Abarth went to a lot of trouble to iron much of this out in the 130TC and at the same time keeping it road and speed bump friendly. Just take a look at the level and equal length drive shafts, inverted front hub yokes and engine stabiliser bars.
Having said all this the 130TC's "nose in the air" posture has upset many. However this could have been a subtile Italian true "nose in air" to the Golfs GTI's and Ford RS 1600/200os of the era. :)
now I been told that Fiat X1/9 and Lancia A112 got the same springs as my car.. maybe..
Anoyone who can confirm this?
Would make my job alittle easyer, since there are 0 lowering springs in stock for a 130 TC.. :p
no way will they have the same springs. The abarth will be weighted quite differently to these smaller cars. Having lowered two 130tcs i would get the original springs retempted or new set made up.
Measure static height of spring when on car and then take to spring makers and tell them how much lower you want it. They can measure your current springs and spring rates. They can then make some to suit that can have same or up rated spring rate but at a lower ride height.
Hope that makes sense
Get them made up at a local engineering place or spring manufacturer - wont cost much - more you order cheaper it is so maybe find other owners who want their 130 lowered
:slayer:
Hello,
I have just lowered my Ritmo 1,5L with the original Uno 1.3 70 mk1 springs (1983-1985) They have the same measurements, only the are shorter.
Lower diameter 143,3mm
thikness 12,1mm
Lengt 328mm
The ritmo is standing nice and straight now, gifs a lowering about 50mm.
Maybe the springs will fit a 130TC Abarth, but of that i'm not sure.
Very nice strada you have there.I have one of those grills aswell for my strada:cool: There's a 130TC in London with those wheels & he can't lover his front for fear of rubbing on the arches:eek:
Hi guys..
I have same problem i would like to lower mine too.konis used to make adjustable coil overs for abarth 130 tc,but not anymore!!:(
