Oli-M
i've got a GT back axle for my '99 sporting, for the rear disks, but want to balance the front with the GT calipers (and use the tarox vented disks i got with the back axle).
i just need to know if the wider calipers a straight swap, as in mounting lugs and caliper carrier offset. they're ATE calipers on it atm. i've noticed stilos and bravos appear to have the same calipers as the GTs, but do any of you know if they are a direct swap and can be run with GT disks?
also, will i get away with keeping the sporting master cylinder? i appreciate the GT calipers have bigger pistons, but is the difference within limits?
i suppose i could technically have a dig in the scrap yards, but it's bloody freezing!
any help much appreciated
oli
oli
