zokipet
I have Punto 75 SX from '98. I was a great car till start showing two problems.
1. First and greatest is battery emptying problem. In fact, very often (aprox. 2-3 times/month) I can't start the engine because of empty battery. I bought new one, but the problem remains. The good thing is that when problem occur I swap the batteries and charging the empty on AC charger out of car for the next swap. Electrical charging on the car seems to work OK - on long trips battery remains full even on night driving under light and with car stereo on.
2. Second problem is electronic check light. Often (3-4 times/week) whet I try to start the engine electronic check light remains to light (red) and ignitions is weighty. In this situations engine fan switch on and blow. After few kilometers everything go back to normal - engine work normal, check light and fan switch off. Nothing changed after replacement of temperature sensor.
Any advise will be very helpful.
Thanks in advance
Thanks in advance
