You will most probably never need it. It's for immobliser problems or to re-programme 2 new blues, that are cloned off a red
If you only have 1 blue key and you car is between late 1995 and 2000 get it cloned now, if the car is out side of these dates it would have never had a red key.
You can check for the code2 system by looking on your key. If a circle/triangle/2 symbol is stamped onto the key then it is code2 (see pic)
No matter what design key your punto has - if it has that code2 symbol it never had a red key
