The indicator (left) stops flashing when i press on the brake pedal. This is quite anoying and also dangerous. Any ideas on why this is happening? cost to get fixed? it is a 1995 55s
give them a good clean and then slightly bend the terminals so that when you reconnect them the terminals will be pressuring against the receivers making a good solid connection.,.,
Re: Indicator stopping when i press the brake pedal
sounds like a bad earth. remove the lamp,remove the bulbs,clean the contacts of the bulbs and the contacts of the holder using a screw driver to scrape the contacts,also bend the contacts upwards so they make a good contact. .............
