paulsmith109
My Punto 60S is making a strange groaning/whining type noise. Thought it might be a cam belt drive bearing but garage thinks the radiator ccoling fan motor (bearings?) may be knackered and have suggested a new fan motor. Has anyone else had this fault? And why would the fan motor be running during a normal cruise at 50mph anyway. Is the cooling system knackered completely? The coolant level is fine and the water pump is NOT leaking but the engine compartment does seem rather hot after a shortish journey. Air lock perhaps. The auto fan does cut in correctly at a standstill.
The garage have carried out a Block Test to check out the Head Gasket but that is absolutely fine thank goodness. But why would the fan motor run during normal cruise speeds anyway. The car is overheating perhaps? The temp warning light has never been on! Has anyone else experienced radiator cooling fan motor faults. Should I get the coolant system bled for airlocks and refilled??
Any advice or thoughts anyone please!!
