I had a prob with a leaky heater matrix a while back, and it's a simple enough thing to sortif you just bypass it. This means you don't have any heat, mind, but it's a hell of a lot easier than replacing it! You'll need a u-bend and a couple of jubilee clips. (both easy enough to pick up from a diy store) You'll need to measure the diameter of the tubing to match though. I assume you've done something to sort this prob by now, but thought i'd share my experience. Anyway, if the heater matrix is leaking, you'll lose loads of water and your engine won't cool. If you pop the bonnet, you'll see 2 pipes going centrally into the bulkhead, fairly low down-these are the inlet and outlet valves which take the water to the matrix behind the consol in the car. All you do is disconnect these 2 and attach them together. If you're not sure which ones they are, you can follow the pipe where you put the water in for the engine coolant.
