Technical 60mm lowering mk1 punto
derby
hi guys jus bought sum 60mm springs for me punto jus wondered if any1 knows the pros and cons of fitting these? its already lowered 35mm but got bored as it still sits too high 4 my liking!:D
Depends on if your fitting them with shortened shockers ?
pros
handle better (if the road isnt bumpy)
less lean
Looks good
cons
To low
To bumpy
You will have to come almost to a stop before going over a speed ramps
Also if you got more than one person in the car and you arnt all lightweight then you will end up leaving your exhaust behind.
Did i mention to low ;)
alrite cheers! only ever have 2 people in the car myself and the mrs but goin slow over the speed ramps doesnt bother me it looks im after! can never be too low surely?:D
it'll be fair low!
if you are using std wheel size (width as well) you won't have any clearance issues under there.
the suspension may actually ride terrribly at that height, the front shouldn't be too bad.
but the rear will struggle, thoughs trailing arm things will be like /
