General changing rear wiper motor (mk1) info required
Stedy76
Northumberland
Hello everyone, could someone please help me, and write a short "step by step" for this procedure? I'd be very greatful!? p.s. a tool list would be great help too;) .
thanx
Stedy
lift up cap on end of wiper arm, remove nut and wiper arm, open the boot, remover inner cover, then remove electrics, undo mounting bolts, remove and replace with new one, but before you put the wiper arm on turn on the rear wiper and then turn it off (so the motor is deffo in park position) now reit wiper arm (park position along the bottom of the screen) and do nut up, filp cap down job done.
Don't forget the boot will have to be closed to get power to the motor.. Also the spray wash has an adjustment on the arm ;)
ok smart arse ;)
my rear spray has never worked.
