Old 27-07-2006   #1
Fiat Punto 55s 1994 rear offside spring upper plate mounting
Problem with a corroded upper offside suspension spring plate cup. The rubber bump/ bung metal retainer that is suspended from the top plate metal cup and sits inside the rear spring has a rusted cup and has dropped inside the spring. There are no handling problems and all is ok. Is it there to stop the spring bottoming when fully loaded? How can it be replaced? Is the part available thro Fiat? The top plate is not corroded and the spring mounts both ends are good, its just this cup thing thats rusted.
Welcome some advice.
tinpan
tinpan is offline Reply With Quote Quote
Old 27-07-2006   #2
jug
blessed are the apostates
jug's Avatar
Trader Rating: 1
jug has donated!
Re: Fiat Punto 55s 1994 rear offside spring upper plate mounting
its just the bump stop mount, and you're right it does stop the suspension from travelling too far (bottoming out) when under heavy load. not important really, but easily replaced if you want to, i suggest a scrapyard where the part will be a couple of quid.
2.0 twinspark veloce
jug is offline Reply With Quote Quote
Old 27-07-2006   #3
take a few photos if you do. Got same job on my 1995 turbo, and thought it may need more than an easily replaced component.
Dave Boulton is offline Reply With Quote Quote
(T) Fiat Punto 55s Code/Immoboliser system bazoooka Punto (Mk1) 0 23-06-2005 21:02
MODELS FIAT SHOULD MAKE! jetweed Lets Talk FIAT 61 30-08-2004 21:38
I.C.E for 1994 Fiat Punto Sport 55 - help! willay I.C.E 5 06-09-2002 19:20
