Doctor Dave
I've got a 1995 Punto Selecta 1200 which I have put a replacment gearbox and electro-magnetic clutch in. it has done a few hundred miles fine without any problems. recently, it has developed a problem where it jumps when idling in gear, like the elctro clutch is grabbing all of a sudden instead of comeing in gradually on acceleration.This usually causes the car to stall.When this problem occurs and you shift to neutral, you can't get the car back into gear because the electro clutch is biteing all the time. The only way to shift it through gears and to park is to turn the engine off, start it again and you can shift, but not for long before the problem comes back. The car still runs and drives fine once your moveing in gear.
Can anybody help. There's so many sensors and actuators I don't know which one is giving the wrong signal to the clutch unit.
