sono511
Ok here's for everyone who want's to know how to get a Punto Mk1 gearknob off. PULL!!! Pull with all your might!!! There are so many posts saying that you need to cut it off screw it off etc etc, but you don't.
You unscrew the base (the bit on the floor that the horrible rubber bit is fastend to) and pull it up. The gaiter will turn inside out and not come right up because of the actual knob at the top, then grap your knob (hehehehe) and pull directly upwards, its really stiff but eventually it's give.
All you need to do then is buy a new gaiter because the old ones nasty and has a knob in the end of it, put the gaiter on the stick, the base on (with old gaiter removed) and then your new gearknob and hey presto, simple really isn't it.
My mum says im cool...even if my friends dont...
