Old 30-03-2006   #1
Unhappy problems replacing fuel filter Punto 55. 1996
I have a leaking fuel filter and Iīm trying to remove the old one. Itīs just that canīt seem to loosen the plastic fittings between the filter and the hose. I donīt want to force the pieces apart.
Is there a particular way to detach this?
webster is offline Reply With Quote Quote
Old 08-04-2006   #2
Re: problems replacing fuel filter Punto 55. 1996
Squeeze the two clips and before pulling the filter away from the pipe push the filter towards the pipe then try to detatch it. When fitting the new filter make sure its pushed home you may hear a small click but will feel it when fitted properly. Hope this helps
dave55mk1 is offline Reply With Quote Quote
(T) Fuel Filter firefly Cinquecento / Seicento 15 20-10-2007 15:09
(G) Punto Sporting (New Shape) -Too Many Problems Dee Punto (Mk2/2b) 18 18-10-2007 13:10
(T) More problems... fuel injection warning light Martina Punto (Mk2/2b) 4 19-11-2004 21:54
(T) Fuel filter Advanced Driver Cinquecento / Seicento 3 17-08-2004 20:45
(T) Punto 75ELX couple of problems?? Joske Punto (Mk1) 5 23-04-2003 13:03
