bioing
hello all
am new to this forum, and know next to nothing about car engines..
i have a problem with my 1998 1.2 punto sx
for the last few days my temp gauge has been getting hotter... but not too hot, and cooling fan has been kicking in ok.
i got in the car last night.. drove about a mile and the car started feeling really "hicky" each time i slowed down and the revvs dropped off.. it felt like it was going to stall.. but was ok when revvs were high.. i also noticed lots of white smoke/steam coming out of exhaust.. about a minute later.. the smoke stopped and temp went sky high (way past the red mark).
unfortunately i was on a stretch of dual carriageway and was not going to stop the car there as if it didnt start again i knew id have no wheels and smashed windows the next morning.. i made it to the next turn off which is opposite the local asda.. let the car cool down and checked the oil/water.. oil was very low and water seemed empty (it was dark so hard to see but the container thing for water was cold and as car was overheating id assume this should be boiling hot) i went over to the asda and got some oil/water and topped car up... (took a full 1.5l of water!!!)
on restaring at first no white smoke out of back but engine sounded clunky and revvs still dropping off at idle.. but temp stayed low (at the first quarter mark).. soon though the white smoke/steam from the exhaust came back in abundance.. but i managed to drive the 5 mins back home... and temp stayed low all the way..
i havent started it this morning, but i had a quick look under bonnet and there was alot of oil running down front of engine (excuse my lack of knowledge here) it was basically on the front of the engine (the big block bit i would call it) coming down from where the top part is stuck to the bottom part..
is my cyclinder head fcuked do you reckon??
any help/advice would be much appreciated. roughly how much should it cost to get repaired by a small reliable local garage?
Lee
Lee
