i want to fit punto gt dials into sisters car but id rather them not have 140 odd miles on when her cars less than 60k, so how can i lower the mileage on the pod? thanks.
wouldnt bother with the dials. technically you need to inform the insurer.
you can move the dials but it tends to put them a bit out of alignment and you could bugger them up completely
When mine was replaced i asked for them to write the mileage of the new and old speedo on the reciept and i have the old speedo to prove the mileage. As long as you can prove to the next owner its genuine. Why are you fitting GT dials Beau, ?
but half the gauges won't work, get sporting plasma dials instead.
You can clock puntos quite easily, I tried it with my new ones, but they ended up all out of align, and every time I put the lock pin back in I ended up with 174k rather than 74k, so I just swapped the actual speedo pod bit around, as you have to unplug it anyway!!
When me and a mate forwarded the clocks on a polo, we used a tape player with a metal rod attached to the tape-player-bit and put the speedo cable on it had to leave it on for days though. Or you could set up a drill to do it maybe.
