Old 2 Weeks Ago   #1
France
airbag light on (MK1)
I was doing some repair on my father's punto MK1. Like an idiot I removed a fuse without disconnecting the battery first. We now have the airbag light on the time. I think nothing's wrong, it just fired an error and copied into memory.
the fuse I removed is under the small black block under the windscreen in the bay engine.
Where is located the ECU module ? (behing the radio I read but not sure). I'd like to write down the module ID.
It seems that those cars don't have a OBD2 port but rather a diagnostic port for the airbag module. Is there a recommended tool to talk to it and try to reset it ?
If I change the module, is it a plug-and-play type of operation ? (I guess it is considering how old the car is)
thanks !
electricFuzz is offline Reply With Quote Quote
Old 2 Weeks Ago   #2
Bugs Beware!!
Noddy's Avatar
Noddy has donated!
Add Like Mad Champion, Badger Race Champion, Bumper Golf Champion, Super Mario Mushroom Champion, Valentine Surprizes Champion
Re: airbag light on (MK1)
The airbag module/ecu is located behind the center console, between the gearstick and bulkhead. Its mounted to the tunnel section.
What work did you do when you disconnected the fuse? Have you tried disconnecting the battery for a couple of hours and reconnecting?
From memory I dont think either MES or iaw ecu scan will do airbag but cant confirm without checking.
WHEN GOD SAID SIX PACKS I THOUGHT HE MEANT BEER, SO I ASKED FOR A KEG
THE ONLY THING I CAN SEE MY TAXES BEING SPENT ON IS MORE WAYS TO TAX ME
Noddy is offline Reply With Quote Quote
Old 2 Weeks Ago   #3
France
Hi Noddy, thanks for the reply.
Quote Quote:
nothing to do with the electronic and the sensor of the car. We changed the oil pan, the timing belt, the thermostat. I disconnected the battery for less than a hour. Maybe I'll try to remove the connection for several hours.
Quote Quote:
That's what i'm afraid of and at the dealership it can cost an arm and a leg. Let alone if they still have the tool to read the module memory. (I had the experience for another car which is even more exotic than a fiat punto! )
Old 2 Weeks Ago   #4
Its Adventure Time!
blu73's Avatar
Trader Rating: 2
blu73 has donated!
Skate Boarder Champion
MultiECUScan can connect to the airbag and ABS modules, you can't connect to it from the normal diagnostics port by the ecu as thats just for the engine ecu..
Theres another port (same fiat 3-pin) for the airbag, thats the one inside under the centre console area. And theres another one for the ABS system which from memory is by the ABS pump in the engine bay - sorry its been about a decade since i had a mk1 punto so thats as precise as i can remember.
But look near the ABS pump for another 3-pin diagnostic connector the same as the one by the ecu. Connect in the same way as ECU, so fiat 3-pin adapter to KKL/Vagcom cable to laptop and it should connect up and read/clear codes just fine.
Likes Noddy, varesecrazy liked this post
Finn: Panda 100HP
Oberyn: Suzuki Ignis Sport
PEX: Cinq Track Car
Some previous cars: Bravo HGT, Cinq 16v, Sei Turbo, Punto GT, Panda Mania 1242 mpi
blu73 is offline Reply With Quote Quote
(T) fan heater not working and now airbag light on and passenger airbag light constant fl mikehopper Punto (Mk2/2b) 30 04-10-2015 19:52
(T) Airbag light on passenger airbag problem - Fiat Idea GRBASF Idea 6 06-04-2015 22:03
(T) Mk1 75sx Punto Airbag warning light on. Weebl Punto (Mk1) 7 01-08-2013 11:38
(G) Airbag light on Mk1 punto andyr Punto (Mk1) 19 12-12-2006 23:52
