Old 22-05-2021   #16
Quote Originally Posted by Feraty View Post
Hey all, has been a while. Project is almost ready for the dyno, after some setbacks i still need to do a couple of things. I got the abs sensors for the GT front axle, but i dont know how the cable is routed. Perhaps missing some componentsÖ.
I could get some photos of how the cables are routed from mine if thatís any use 👍🏻
Thanks Feraty thanked for this post
Steve gt is offline Reply With Quote Quote
Old 22-05-2021   #17
Feraty has donated!
Netherlands
Re: 244 Large Mondrian Blue fabric
Quote Originally Posted by Steve gt View Post
That would be great!
Punto mk1 60sx Tjet swapped
Feraty is offline Reply With Quote Quote
Old 28-05-2021   #18
Feraty has donated!
Netherlands
Almost there….
Likes Steve gt liked this post
Old 28-05-2021   #19
Hope these help 👍🏻the cable clips onto a bracket thatís bolted through the bottom of the inner wing , then runs forward and up the inside of the engine bay to a connector, couldnít get a photo of that as itís too close to the engine.
ID:	218028   Click image for larger version
Likes varesecrazy, Feraty liked this post
Old 28-05-2021   #20
Feraty has donated!
Netherlands
Thanks a lot, bit of a weird routing isnít it?
I bought the damper brackets, the other ones i need to make or make a different routing.
Anyways, there might be a bigger problem. I ran the starter and after a couple of times still no oil pressureÖ. The car is on stands ar the front, so it could be not enough oil but i have my doubts. I do read it takes a while to fill up the system on a tjet after it has been sitting for months but stillÖ
Old 28-05-2021   #21
Yeah, Iím sure you can make something up to route them 👍🏻, mmm not sure about the oil pressure problem , hopefully it will be ok 🤞🏻
Old 28-05-2021   #22
Its Adventure Time!
blu73's Avatar
Trader Rating: 2
blu73 has donated!
Skate Boarder Champion
how long were you turning it over each time?? A good trick to make it all happen faster and take strain off bearings is to do it without compression, so disconnect the crank sensor or however you are stopping it from injecting fuel, take all the plugs out, then turn it over - will spin much much quicker and without the compression theres next to no load on the crank bearings...
Finn: Panda 100HP
Oberyn: Suzuki Ignis Sport
PEX: Cinq Track Car
Some previous cars: Bravo HGT, Cinq 16v, Sei Turbo, Punto GT, Panda Mania 1242 mpi
blu73 is offline Reply With Quote Quote
Old 28-05-2021   #23
Feraty has donated!
Netherlands
Just a couple of seconds, sunday i will mount the anti roll bar and lower the car. Then ill check the oil again and top it up. Maybe priming the pump via the greenfilter/cooler assembly. The oil pickup does sit in the front half of the oil pan
Weird thing is, i bought the engine and gearbox with fluids. When i got home I drained it all. The oil was used, quite dark actually but no shavings. So i guess the worst thing could be the pick up or seal for the pick up?
Old 29-05-2021   #24
Its Adventure Time!
blu73's Avatar
Trader Rating: 2
blu73 has donated!
probably worth dropping the pan for a quick looksie if you haven't but I think you're just being a bit paranoid.. will take a good bit of turning over to prime everything, I don't think there's a way to just spin the pump on a fiat fire without the engine (but also not a thing I've ever really looked into). But you can pour some oil into the turbo oil feed to lubricate the turbo on the startup, other than that from what you've said I'd not be at all worried yet.
as above, whip plugs out before you try next time and just keep going for longer, so long as your not going for minutes and minutes it'll be fine. Give it some 15-20 second bursts with a minute or so in-between to let the starter cool down. I'd expect the light to go off on the 2nd or 3rd attempt.
Maybe worth just checking the wiring for the light too, cause it's possible it's just shorted to earth and won't ever go out lol
Likes Feraty liked this post
Finn: Panda 100HP
PEX: Cinq Track Car
Old 31-05-2021   #25
Feraty has donated!
Netherlands
Good news everyone!
Thanks blu73, pulled the plugs and after 4x 20 sec turns it finally gave some pressure (whopping 3 bar worth)
Bad news, started filling up coolant until my coolant pipe started leaking at the welds. Anyways removed the pipe and gave it to a local radiator welding shop. Will be done tomorrow…
Likes Steve gt, blu73 liked this post
Old 03-06-2021   #26
Its Adventure Time!
blu73's Avatar
Trader Rating: 2
blu73 has donated!
excellent news with the oil pressure! leak is annoying but a small little issue easily sorted..
Finn: Panda 100HP
PEX: Cinq Track Car
Old 11-06-2021   #27
Feraty has donated!
Netherlands
After some fiddling, it starts and runs. In the end there were a couple more leaks in that coolant pipe… need to improve my welding skills a bit more next week orso it will go on the dyno and get mot after. I will upload some videos, via YouTube perhaps?
Anyways cant wait to drive this thing. After this ill take a break, do some stuff around the house and the brembos ofcourse but all in a slow pace. And just enjoy the car as is
Likes blu73, Steve gt liked this post
Old 2 Weeks Ago   #28
Feraty has donated!
Netherlands
Hey all,
Couple of months later the car went on the dyno and came of it in one piece !
But one day wasn't enough so i went back another day for the last touchups.
this is taken at day one, the second day we tuned the higher revs and pushed the torque band just a little bit wider. but in general there must be a restriction, probably the stock Punto gt exhaust.
because we couldn't get it higher than 160hp. and most abarth 595 with IHI turbo push 170 with out the uprated intercooler and such.
so i think there is still power left on the table.....
anyways it drives great and was a worth while. cruise control still needs some tuning but works fine for now.
yesterday i went for a cruise
avg fuel consumption at the pump: 13,5 km per L or 38.17 UK mpg
with all that fun under the bonnet, the brakes are up to big task and are really too small for this. but thats for an other time, just like electric hydraulic power steering....
(T) Bg-244 TangerineTractor Stilo 0 11-11-2011 09:40
Blue 3 door stilo with large FF sticker on rear bumper kayaker-ant Spotted / Was It You? 2 15-04-2008 19:03
