westernlancia
Hi folks
I have an odd problem. My oil sump has rusted through at the front! I say 'an odd problem' because usually Fiat/Lancia engines leak enough oil to stop this! Anyway, it has gone very porous and has a number of pinholes. I fixed it a couple of years ago with fibreglass matting and silicon, but that's not really a long-term solution because the oil gets under it from behind and makes it come unstuck.
So - my question. Has anyone else done the job? I have had a quick look underneath and it doesn't look as if the sump will come off easily without removing other stuff and/or taking the engine out! It could be a case of having to keep re-fibreglassing it, but I'd like a permanent fix.
And as mentioned in other threads, my car is actually a 2000 model Lancia Y Elefantino Rosso, but they are mechanically identical to the S1 Punto 85.
