Thread Tools
Old 2 Weeks Ago   #1
Sun visor (drivers side) A lady needs help.
Does any one have a drivers side sun visor (light grey) for a 1997 Cabrio ...it has a slidy mirror. Mrs Punto1cab has one that has gone all floppy! It is clearly a fit & forget item that is all plastic welded up! I imagine the shaft has broken or something. Only identification is on the bracket & that says A203
I don't know if it unique to the Cabrio....as the screen angle seems more acute on the Cabrio, it might be.
Punto1cab is offline Reply With Quote Quote
Old 2 Weeks Ago   #2
varesecrazy has donated!
Quote Originally Posted by Punto1cab View Post
Our 55s did that.
I packed IT out IIRC.
Just enough to make it stiffer.
SEARCH should find more info..
My repair was 10 years ago..
Charlie
Old 2 Weeks Ago   #3
renaultvation has donated!
Re: Sun visor (drivers side) A lady needs help.
There is a spring steel clip within the visor which grips onto the flat edge of the spindle. When the clip breaks it loses its grip. Although the visor is unique to the cabrio, the clip isn't. I have replaced mine with a clip from a non-cabrio punto, which was a fraction of the cost of a replacement cabrio visor. However, you do have to cut the vinyl to access the clip. If you remove the visor and feel along the top edge, you will feel the position of the clip. When you have located it, make a small incision with a sharp knife along the top seam and you can simply remove the broken clip and replace it. I then used a vinyl bond glue to repair the cut which created an invisible repair.
renaultvation is offline Reply With Quote Quote
Old 2 Weeks Ago   #4
Quote Originally Posted by renaultvation View Post
Thanks for that information. I have removed the broken clip (I made too long a cut, but it will glue back as you say) Any tips on which visor has a suitable clip? Mk2? or what. no Mk1's around, unless someone reading this has one ?
David
Old 2 Weeks Ago   #5
Italy
There are a few on Italian Ebay.
Search for
PARASOLE-PANTINA-DESTRA-con-specchietto-FIAT-PUNTO-1-serie
Destra or DX means right hand
Italian Job is offline Reply With Quote Quote
Old 1 Week Ago   #6
I used a clip from a mk1 visor. When I last needed one I managed to find one on UK ebay.
Old 1 Week Ago   #7
Quote Originally Posted by Italian Job View Post
Search for
Thanks for that info...I have had a few parts from Italy e-bay, but on most occasions they won't post outside Italy!! The patience of Italian friends who have done the deals for me is a bit thin now!
Old 1 Week Ago   #8
I might be inclined to take a punt(o) on a cheap mk2 visor and see if it has the same clip: https://www.ebay.co.uk/itm/Fiat-punt...8AAOSwJo1bX0tS
Old 1 Week Ago   #9
I might be inclined to take a punt(o) on a cheap mk2 visor and see if it has the same clip: https://www.ebay.co.uk/itm/Fiat-punto-sun-visor-passenger-side-99-06/223575682643?hash=item340e262e53:g:BH8AAOSwJo1bX0t S
Maybe I will do just that
I will let you know!
Old 1 Week Ago   #10
Spain
This is a BIG problem that I have only solved by fitting the visors from the mk2 version, they are too long and don fit at all but at least they don't flop down in front of your face.
rolandbrindley is online now Reply With Quote Quote
Thread Tools
(S) Drivers sun visor with mirror..... itsnotmine 500 20 24-05-2016 14:39
(G) Driver side sun visor fcuk Bravo 2 19-07-2015 08:37
