Technical Funny Clutch problem
Matts Dad
Member
Hastings, United Kingdom.
Hi Guys
Just bought a 55S after a test drive.
What didn't show up then (but did on the way home) is that if you sit with your foot on the clutch (eg: in queue ot T-junction waiting to move)after about 45 secs (but NOT immediately) a noise like a loose exhaust pipe rattling starts up. Stops immediately the clutch is let up. It is not dependent on position of gear lever - happens in both 1st & neutral.
This is not repeatable but a 1 in 5 occurance.
I haven't actaully worked out whether it is the engine shaking (eg: a misfire - but caused by pressing the clutch???) or something inside the clutch housing (my favorite theory).
Before anyone says clutch bearing on the way out, the noise is NOT a squeal like that, it is a rattle.
All ideas welcome.
Also - the radio wants a code to be entered but the code on the vehicle documentation doesn't work. Alternatives to buying a new radio please?
all things must pass.
radios can usaly be recoded at a car audio shop about £10 £15, or fiat may have code on central computer but as its fiat if they have it they will charge for it.
Please do not Email or PM me asking for support. Post on the forums instead. Your reply may help someone else. Thank you
