Thread Tools
Old 08-09-2018   #16
Moderator
g8rpi's Avatar
g8rpi has donated!
Re: How to scan the car
Quote Originally Posted by Diberto3 View Post
Plug your car code reader into the diagnostic link connector under the dash (engine off). Then start the vehicle and follow the code reading procedure in the instruction manual.
The question raised was about the earlier cars with a 3 pin interface (under bonnet). Your instructuons and most code reders won't work on this car.
Robert G8RPI.
g8rpi is offline Reply With Quote Quote
Old 13-09-2018   #17
Germany
I have a 1995 1.6 convertible (88hp). I have the connector but don't know which software can i use in order to read ECU.
Can anyone tell me how to read the ECU in this car?
Thanks!
chkto1000 is offline Reply With Quote Quote
Old 13-09-2018   #18
Moderator
g8rpi's Avatar
g8rpi has donated!
Quote Originally Posted by chkto1000 View Post
Thanks!
Multiecuscan is probably the best software www.multiecuscan.net
You can check your exact model here http://www.multiecuscan.net/SupportedVehiclesList.aspx. If the module is listed in red you need the registered version. Interface needs to be a USB (or serial 232) KL / Vag-Com type plus a 3 wire adaptor.
If your car has an Magneti Marelli ECU you could try IAW Scan http://iaw-scan2.sourceforge.net/
Robert G8RPI.
Old 14-09-2018   #19
Germany
Quote Originally Posted by g8rpi View Post
Robert G8RPI.
As I saw it, my ECI is from GM, and Multiecuscan can't read this model's engine ECU. What sofatware can I actually use in order to read the engine ECU?
Old 14-09-2018   #20
Moderator
g8rpi's Avatar
g8rpi has donated!
What ECU (model number) is fitted to your car?
Robert G8RPI
Old 14-09-2018   #21
Germany
Robert G8RPI
All that is written:
GM 16214289 176 1.58L MAN
and
BP JZ 034
made in UK
Old 14-09-2018   #22
Moderator
g8rpi's Avatar
g8rpi has donated!
and
BP JZ 034
made in UK
That is a Delco / Delphi ECU. They are not supported by Multiecuscan. You might be able to use software desigined for GM / Opel / Vauxhall cars e.g. Corsa. I think early GM cars used 10 pin socket so you would have to look at the wiring diagrams for both and work out the connections. Even then there is a good chance the software won't talk to the Fiat. Also I think the ECU is coded to the ignition key, lock and immobiliser so you have to get a set if fitting used parts.
Robert G8RPI.
Old 20-09-2018   #23
Its Adventure Time!
blu73's Avatar
Trader Rating: 2
blu73 has donated!
Skate Boarder Champion
IAW Scan is fine for mk1 punto 55, 60 & 75. It should work fine with the 85 too but I've always had issues with it and the P85 ecu. I'd give IAW Scan a go first before paying anything for MultiECUScan @alexgm Its actually a really neat bit of software, should do anything you'll ever need it to do.
When it comes to the 90 I've never managed to read the codes, it must be possible but its not something I've ever needed so never put much effort in.
And just to be complete, a GT has a bosch ecu and you can do a blink test where you bridge some wires and the light on the dash blinks out codes. I have more info on this is anyone needs but I wont go into it here as that not what anyone has asked.
Finn - Panda 100HP - thread
Oberyn - Suzuki Ignis Sport - thread
Some previous cars: Alfa 159, Bravo HGT, Cinq 16v, Sei Turbo, Punto GT, Panda Mania 1242 mpi
blu73 is offline Reply With Quote Quote
Old 23-09-2018   #24
French Polynesia
All right, thanks alot @blu73 and especially @g8rpit for your support. I'll try soon the connection on the ECU and give you a feedback as soon as i receive the materials. I'll try the free software IAW scan first and see what it's like
alexgm is offline Reply With Quote Quote
Thread Tools
(T) Scan tools merovingian Ducato 6 27-02-2018 20:54
(T) ECU scan P dot co dot Punto (Mk2/2b) 5 13-05-2015 12:55
(T) Engine warninglight-to scan or not to scan.. nuddmann Multipla 1 23-10-2014 18:59
(T) OBD Car Diagnostic Scan Tool to my Punto kennyboy1704 Punto (Mk2/2b) 8 13-02-2012 21:29
(T) ECU Scan M30SJM Ducato 1 11-04-2011 22:16
