Hi all!
I am new in writing at this truely great forum, but I have been reading here a lot in the last couple of months, since I got my little Punto, so I would truely appreciate any help offered.
I wrote long becaue I wanted to describe my problems thorughly, so please be patient with me and read till the end.
1st question: can you please point me exactly to the location of the engine ECU? I am breaking my head and not sure where it is.
2nd question: does anyone have a PDF of the manual of this model (Garage / mechanic booj)? I got other books but I could not find anything fot this model.
and now comes the reason for my frustration and troubles since I got the car:
3rd question - big problem:
Since the beginning, the car would light the "check engine" light after driving a few km ans stay constant (the red light that looks like an injector) and after that it would hesitate (I guess this is the correct word: lose power and do "kangaroo jumping" - like there is some problem with electric current cutting, or fuel block). I could turn the motor off (simply while driving) and on again and it would go away for a few km, and than come again - and again restart.
What I noticed is that the car will not reach work-temperatue - worked cold (by looking at the dashboard). So I changed Thermostat and temperature sensor (attached to the Thermostat) - after that the temperature was working fine, but: I would start the car cold, and in the moment it reaches work-temperature the check engine light would come on and after a couple of minutes the problems would begin.
in the last 2 weeks it became worse: the kangaroo jumping is worse, the car will not rev (reach about 1500 rpm and will not drive: the accelerator will n ot react - just like there is a blocking on the gas and something is stopping it). by idle, mostly it idles fine and quiet (800 rpm) but the problems begin when driving, and then when trying to rev up also while standing, it will not be ok - no rev up. The car drives bad since the beginning of the ride.
I tried several things over the last 2 months:
I changed: oil & filter, spark plugs and Leads (cables), air filter, Lambda sensor (2 days ago), changed MAP sensor (I believe it is called that name: black square sensor with one small rubber pipe attached, located almost in the back of the engine compartment, behind and over the enging block. I also tried cleaning EGR valve. I tried several times ECU reset (after reading instructions: Battery cables disconnected, switch on/off, starting and letting warm up for about 15 minutes)
Plkease note the Lambda sensor: after changing it, I started from cold engine, drove about 10km beautifuly - very quiet, NO warning light and NO problems. The next day (yesterday) it was the same: about 10 km beautifuly, BUT - after stopping for 5 minutes I started driving again, and after a few hundred meters hell broke loose - it started again (but without warning light). After that it started again to drive in the worst situation with warning light comes on sometimes for a few seconds and dissapears. Will not go over 30mkh and will not rev up. Also, I heard small backfires coming from underneath.
This is it. Could any of you experts here please please help me? I am lost, but I really love this small convertible - would hate to give up on it because of something that in the end will be probably as easy as...
Thanks in advance!
Thanks in advance!
