Thread Tools
Old 09-07-2018   #1
Netherlands
Unhappy Backfire
Hello!
I have this little problem with my 1.2 8v 60HP... We are going on vacation with it to Hungary on friday. So I fixed a vew things, brake lines, brakes, oil change, sparkplugs, sparkplug wires and even coils. Magnetti Marelli coils. The clutch is fresh, gearbox oil as well... The car is almost brand new...
BUT... even before i changed the coils, the car started "puffing" from under the hood when i accelerate from low RPM's. It also won't accelerate that fast....
The sparkplugs and everything is OEM from the FIAT dealership.
Does anyone have had the same problem? Or any ideas? Is it injecting too much fuel? Do I need to adjust the fuel pressure on the injector?
Fiat Mutlipla BiPower LPG 2000
Lancia Ypsilon LS 1.2 8V 1999
Lancia Ypsilon LX 1.2 16v 1998 86pk
MultiRacer is offline Reply With Quote Quote
Old 10-07-2018   #2
South Africa
Re: Backfire
battled with my punto for days and had to realign timing marks on cam and timing belt pulley.
Likes MultiRacer liked this post
WillieV is offline Reply With Quote Quote
Old 10-07-2018   #3
No strings on me
Eklipze3k's Avatar
Eklipze3k has donated!
Re: Backfire
Yeah, I'd say the timing belt may have slipped a tooth or 2, quite common on these engines and thankfully not fatal as they're non-interference!
Good opportunity to renew the belt, and you may as well whack a new water pump and aux belt in there while you're at it.
Eklipze3k is offline Reply With Quote Quote
Old 10-07-2018   #4
Netherlands
Re: Backfire
Thanks guys,
Have done my waterpump and belt 15000 KM ago, Half a year ago... I think a leaking valve maybe. I happen to have a renewed cilinderhead laying arround... I might just change it. But i'll check the timing as well the belt is a little loose tho
Old 06-09-2018   #5
French Polynesia
Re: Backfire
Hi, i have same issue with my 1.1Liter.
But for me i have grey smoke with gas smell from the tailpipe plus fuel smell on the oil. I changed the injector. I need to take cylinder compression. Might be a leaking cylinder. I hope not...
alexgm is offline Reply With Quote Quote
Old 06-09-2018   #6
No strings on me
Eklipze3k's Avatar
Re: Backfire
Grey/white smoke is usually coolant, so definitely get it compression tested but I suspect head gasket failure.
Old 06-09-2018   #7
French Polynesia
Re: Backfire
no its not the coolant...it stay full...might be the piston rings r som thing
Old 08-09-2018   #8
Bhutan
Re: Backfire
Yes, it can be coolant, at early stage of head gasket failure you can get white smoke and no noticeable coolant level drop (yet).
GrandePunto PL is offline Reply With Quote Quote
Old 14-09-2018   #9
Spain
Re: Backfire
Head gasket failure on my 55S became so intractable that I fitted a mk2 head and 10mm studs rather the standard 9mm bolts. Cured it for good, but it's true that head gasket leakage sometimes begins very slowly without much water loss until it fails completely. See my guide on mk2 head on mk1 Punto. If the engine's never been stripped down expect to find anything at all when you lift off the head, these engines were assembled by machine not humans.
rolandbrindley is offline Reply With Quote Quote
Thread Tools
(G) backfire phoenix1 500 (Classic) 2 04-02-2018 16:21
(T) Backfire! Duncan Panda (Classic) 5 10-03-2012 11:16
(T) Backfire bredsticz Punto (Mk2/2b) 2 03-02-2010 14:05
(T) backfire HELP alexgrfc Punto (Mk2/2b) 6 29-06-2009 17:08
Backfire Tommy L FIAT Boo Archives 22 11-04-2006 14:17
