Yes, that's normal. When you are driving normally there is a flow of air through the radiator which keeps the temperature constant. Once you stop, or are in slow traffic, that airflow stops and the temperature immediately begins to rise until the fan cuts in creating airflow through the radiator again. Provided the fan is kicking in, which you state it is, then everything is ok. You do need to keep a check your coolant level though, as the switch for the fan is mounted quite high up on the radiator and if you let the level fall too much it may not trigger the fan.
A quick word of advice with the 1.6 is to place the ECU in a plastic bag. The reason for this is that it is mounted directly beneath the heater matrix behind the centre console. When your matrix develops a leak (not if, but when), it will leak onto your ECU destroying it. A plastic bag will keep it dry.
