Thread Tools
Old 12-04-2018   #1
Finland
Indicators sometimes work, sometimes they don't?
So my indicators (both turning and emergency) sometimes work perfectly and sometimes they don't work at all, i can drive for 2 hours and they work perfectly then they suddenly just stop working. I want to start with checking the earthing points but where the hell are they? I have a -96.
I was thinking about checking the relay (no idea where it is though) but it's weird because when they work they work perfectly.. Is there some sort of troubleshooting guide for indicators? I'm lost.
Any help is appreciated.
Chumppe is offline Reply With Quote Quote
Old 13-04-2018   #2
renaultvation has donated!
Re: Indicators sometimes work, sometimes they don't?
As it is affecting both indicators and hazards, I would start with the relay. On my 94 90ELX it is located in the little fusebox accessed from the glovebox. It could just be a corroded contact providing an intermittent fault.
renaultvation is offline Reply With Quote Quote
Old 16-04-2018   #3
Sorry, I realise I've just directed you to the electric window relay. The one you want is located under the shroud around the steering column.
Old 16-04-2018   #4
Finland
Thank you! Will check it out later today.
Old 18-04-2018   #5
Finland
I really don't know what the exact problem is, i removed and disassembled the relay and nothing seemed to be wrong with it (no corrosion or w/e).
All I needed to do was to keep it pressed in with a little force for the blinkers to work, so i just placed a piece of tape at the side of the relay as i pressed it in to keep it snug and now it works fine (still do a few days later). Might still be the relay but works for now and it's an old car so can't be arsed to change it before it gives up completely
Old 13-05-2018   #6
Bosnia and Herzegovina
have same problem, hope to get it fixed
COBNET is offline Reply With Quote Quote
Thread Tools
(G) Indicators work - hazards don't! Oletimer Multipla 1 14-01-2016 19:38
(T) Direction indicators don't cancel Bicky Punto (Mk2/2b) 0 31-05-2015 15:32
(T) my Indicators lights don't work when it is very cold gmarimon Bravo / Brava 3 17-11-2010 11:01
Stereo speaker;work..don't work matteo FIAT Boo Archives 2 19-01-2004 00:18
