![]() | #1 | ||
Posts: 3 Thanks: 0 Trader Rating: 0 ![]() | swap 1600 cc engine for 1400 cc engine i want to replace my ruined 1600 cc engine with a good 1400 cc. how easy is it? swap gearbox as well? my punto is a 1995 1600 ELX convertible.
![]() | #2 | ||
Posts: 714 Thanks: 19 Trader Rating: 0 ![]() | Re: swap 1600 cc engine for 1400 cc engine Nearly impossible. The 1.6 is the 128 block and the 1.4 (I'm guessing you mean the 1368cc 16V) is a SuperFIRE engine. The mounts are all different, gearbox and linkages aren't compatible. The 1368 will not bolt up to your box. If you had a 1.2 16V convertible the 1.4 is pretty much a straight swap. To make that engine fit your Punto you would need the mounts from a 1.2 16V and a complete donor (like the Idea I have in the classifieds). The 1.6 Bravo/Brava/Multipla 16V is a bold in conversion but you'll need a complete donor for the loom and bits. Personally I would use the donor airbox and bits as well so it looked completely standard. Unless you're on about the older Tipo/Uno/Fiorino 1.4 8V then it's a straight swap but the weight of the cabriolet could be a bit much.
![]() | #3 | ||
Posts: 1,776 Thanks: 81 Trader Rating: 0 ![]() | Re: swap 1600 cc engine for 1400 cc engine Yes, unless you can find a Tipo / Tempra Engine you‘re Stuck unless it‘s a full transplant from a Punto or 1.6 16V.
![]() | jason83 | Uno | 1 | 14-06-2017 16:40 |
![]() | megatuner | Punto (Mk1) | 1 | 18-08-2011 07:50 |
![]() | rawill | Uno | 4 | 25-05-2011 01:50 |
![]() | M@nticore | Uno | 5 | 26-09-2006 15:52 |
![]() | 127swe | 127 | 29 | 28-09-2005 15:50 |
