Thread Tools
Old 21-12-2017   #1
Ireland
1.2 8v 60s to 1.2 16v conversion. Virgin or immo off ecu?
i have found a mk1 16v ecu that i could use fairly cost effective too. which would be better for me to use on this project. car will basically be a stock 1.2 16v running mk1 sporting engine loom. if the immo is off the car will start wont it?
which would i be better off getting, virgin or immo off as they describe!
the 1.2 8v lump wont go to waste either as it is destined for a seicento!!
Fiatcinquecento is offline Reply With Quote Quote
Old 22-12-2017   #2
Romania
Re: 1.2 8v 60s to 1.2 16v conversion. Virgin or immo off ecu?
I think you need both.
Immobilizer off- so you don't have to fiddle around getting all the other bits required (body computer, keys etc
Virginized- so the ECU will talk to the body computer, abs etc..
Right?
aurick86 is offline Reply With Quote Quote
Old 22-12-2017   #3
Ireland
From my mind( which is probably wrong) if the immo was off, the car would start...
I'm not sure, the page is in Italian too so translated it's a bit of broken English.
Old 22-12-2017   #4
Moderator
g8rpi's Avatar
g8rpi has donated!
I think you just need immobiliser off, a proxi alignment and learnt function reset should sort everthing else out.
Robert G8RPI.
g8rpi is offline Reply With Quote Quote
Old 23-12-2017   #5
As robert said... should be just immo off... meaning allowed to start value would be Yes or 1 in hex
Current car: 06 Fiat Stilo Sporting 150 Multijet
Past cars: 03 Stilo 1.2 Active 16v, 06 Focus 1.4 LS, 98 E36 323is, 97 Astra 1.6, 95 Astra 1.7 TDI, 95 Micra Super S, 96 Almera 1.6 GX, 94 Micra Super S, 97 Vectra 1.6 Envoy, 98 A4 1.8T Sport
dtimmins1985 is offline Reply With Quote Quote
Old 23-12-2017   #6
Ireland
Is there a way I can flash and existing ecu that has immo on from another car, like you said about the hex. Is it done through the 3 pin diagnostic port?
Old 23-12-2017   #7
Ireland
I've been reading about the eprom chip, and I have dissected a old ecu I had from a scrap car that I didnt have the key from, and the chip is socketed not soldered, so I'm going to buy the equipment to read and right a 27c512 chip.
I've decided to do this as I am into cinqs, puntos and I want to do this to more, mostly to save me money from already decided ecus.
Anybody have any insight into this?
Old 23-12-2017   #8
Moderator
g8rpi's Avatar
g8rpi has donated!
Quote Originally Posted by Fiatcinquecento View Post
If you are sure it is a socketed chip a cheap TL866CS programmer from eBay will work. However if it is a plastic molded 27c512 EPROM you will need a new one with a quartz window (UVEPROM) and a UV eraser as well. Alternatively you could use a EEPROM that does not need the UV eraser. The SST27SF512 is the ideal replacement but may be hard to find. A Winbond W27C512 will also work.
Finding what bit you need to change is another matter, but the internet is your friend for that.
Robert G8RPI.
Thanks Fiatcinquecento thanked for this post
Likes DIDCOTT, Fiatcinquecento liked this post
Old 27-12-2017   #9
Ireland
Quote Originally Posted by g8rpi View Post
Robert G8RPI.
I think I've just found another language I'm completly lost when it comes to this sort of thing. Must try and get my head around it even a small bit.
digger58 is offline Reply With Quote Quote
Old 01-01-2018   #10
Ireland
Eprom is the chip that holds a part of the immo code, it can be wiped and effectively no immo on car. I have bought a programmer and I'm awaiting delivery. Building a punto sporting so this will be very handy. It's cheaper as I can do it to several cars as I won few cinqs as well!
Old 02-01-2018   #11
Moderator
g8rpi's Avatar
g8rpi has donated!
Make sure you can re-program and take a copy before you wipe anything. You seem to be describing two memories, 27C512 PROM or EPROM and EEPROM (93Cxx 25Lxx). PROM (or EPROM which is same but has a quartz window to allow erasure) is used to hold the main program on older ECUs. EEPROM is used in small sizes to hold semi-variable data like learn parameters set up and possibly immobiliser codes on ECU's with PROM and in larger sizes (Flash EEPROM) the program memory on newer ECUs that can be re-mapped by electrical connection. These newer ECUs may still have a small EEPROM to hold variables and immobiliser codes. It is the small EEPROM (or equivalent area on Flash) that is erased (or preset with "generic" data) on a virginised ECU.
Robert G8RPI.
Likes Fiatcinquecento liked this post
Old 03-01-2018   #12
I choose you!
blu73's Avatar
Trader Rating: 2
blu73 has donated!
Skate Boarder Champion
well the easiest way to do it is find a ecu that has its og key and codebox, then you just take the antenna off your barrel and tape the key to it and hide that up behind the dash somewhere. But it is getting harder and harder to find a complete set of ecu codebox and key sadly.
regarding the virgin or immobilser removed thing i wouldnt say one is a better solution than the other apart from the virgin one will end up with you having an immobilser. It would be less faff to do that that start copying chips and stuff (unless you have all of the stuff already). If you dont have a ecu, codebox and key all matching and dont care about having an immobiliser then just get one with it removed and you have zero faffing to do (but you will have to tell insurance the immobilser is removed)
Charmander - Panda Mania 1242 mpi 8v - thread
Finn - Panda 100HP - thread
Oberyn - Suzuki Ignis Sport - thread
Some previous cars: Alfa 159, Bravo HGT, Cinq 16v, Sei Turbo, Punto GT
blu73 is offline Reply With Quote Quote
Old 12-01-2018   #13
Ireland
But of progress. I bought a mk2a punto hlx 16v with nct and tax for 200. This is the engine I will be transplanting into the 60. I have mk1 manifold engine loom and ecu.
What I'm stuck is, what is meant by proxi allignment.
To do with the instrument dials?
Old 12-01-2018   #14
Moderator
g8rpi's Avatar
g8rpi has donated!
Proxi alignment is a Fiat procedure that allows the CANBUS configuration to be determined and stored. it can be done with Multiecuscan. The need to do it is normally indicated by the odometer display flashing. Any CAN ecu change will need a proxi alignment.
Robert G8RPI
Old 12-01-2018   #15
Ireland
Both cars are Manuel milage cluster, with the dials, it's a mk1 punto, these don't have the canbus system?
Thread Tools
(T) Seicento MK2(1.4 16V Conversion) - Punto MK1 Ecu - Help Bimmermeister Cinquecento / Seicento 1 17-05-2015 19:56
(T) EDC15C7 Fiat Stilo damaged ECU & immo new ECU virgin/solder MatesCZE Stilo 1 13-09-2014 10:02
(T) Virgin ECU STONKING Stilo 23 06-12-2013 17:02
(T) Immo question on 16v swap with ECU 18FD.5Z vatza Cinquecento / Seicento 6 16-03-2011 20:30
(T) mpi sei ecu problem? / remap time? / Virgin Ecu? ronnieronson Cinquecento / Seicento 20 10-02-2008 15:15
