Hello guys,
as title says, my MK1 is losing water with no visible leak, but it's not overheating (checked with scan tool, when temperature goes above 90 celsius fan kicks in and keeping it at that level). Here are some things I did/checked:
- bleeded system several time
- checked every single part for leaks
- no bubbles in expansion tank
- no heating in cabin as of now
- no steam out of exhaust
- both hoses are warm
- when you turn off the car water coming out of expansion tank
- scan tool showing "System MAX Rich" (recently)
- car is running smoothly, no hesitation
Temperature gadget (not sure that's right word) in cabin showing that car is warmer than actually is. Before, fan would kick in just above middle line, now way above, although scan tool is showing that temperate is not that high as gadget says. I believe some air is tricking gadget and that same air could lead to "System MAX Rich" condition?
Thanks in advance,
Greetings from Croatia.
Thanks in advance,
