Technical Water temp gauge sensor
Hi.
Car is the mk1 1.2 16v 85 sporting.
Slight issue with a dash gauge that barely rises. On a run it does move a bit more but i dont trust or rely on it.car starts and runs absolutely fine so i bought a new temp sender 1 pin red but cant see where this goes.
Does this FIRE 16v motor just have one single sensor for coolant temp or does it have a coolant temp sensor for cold starts plus a gauge sender somewhere on the block cos i can only find one blue 2 pin sensor at the back.....
I also get quite a gurgling sound on start up. Opened the bleed screws in the matrix hoses and nothing really came out but they are hot.
Thanks.
