Hi Folks,
This is my first post on here, sorry that its a question straight off, but I haven't had a real problem with this car before, have it since the 90's!!!
I'm looking for some advice on a 1995 Fiat Punto which failed the NCT/MOT on emissions with the following readings.
High Idle
Lambda 1.31 should be between 0.97 and 1.03 -- fail
CO 0.04% Not above 30% -- pass
HC 40 ppm Not above 200 ppm -- pass
So it only failed on the lambda.
I bought a cable and connected the ecu to my laptop.
No error codes were stored.
The live data for "Lambda Probe Correction" goes up and down on the graph
The live data for "Lambda Sensor in Closed Loop" graph also goes up and down when the engine is revved.
All tests pass, coils, injectors etc.
Car runs great, I'm at a loss with what todo with it next?
Any advice would be greatly appreciated.
High Idle
