If fuel pressure regulator isn't losing fuel out of vacuum port.
You can check fuel supply by disconnecting the fuel return to tank hose , put end of hose into a container , make fuel pump run, if you get a strong flow of fuel returning to fuel tank fuel supply is likely to be good.
You don't need a gauge for that test.
