Technical Mk1 (1.2)engine replacing with Mk2(1.2) engine
Mrdjan
Hello everybody!I'm new here and want to ask one question.Is possible to put in MK1 Punto (1997 , 1.2),engine from MK2 Punto (2000 ,1.2 8v) engine?Also,do I need to make some changes if that is possible at the end..Thanks!
the engine will probably be a bolt-in swap but the electrics won't be you can be sure ! The wiring loom will differ as will the ECU and all in all you may have to settle for using all your earlier injection stuff on the later engine just to get it to run at all.
