luqluq
Dear guys,
I need some advice about the electrical supply for my 1.2 8V Mk1 Cabrio. She has eaten 3 altenators previously. During the 4th replacement, I added a voltmeter wired to the dash and here are my findings during operation:
1. During normal engine running and standing without any load, it reads 13.6V.
2. When signal repeater switched on, the voltage goes between 12.2V and 13.4V. When I switched on the hazard signals (all signal lights on), the voltage went just to 13.4V although all lighted on whereas compared to by turning on the signal, only one side lights switched on.
3. Switched on the dimmer night light (without the head light), the voltage goes to 12.6V and if the head light is on, it just go 0.1V lower
4. Press the brake pedal, the voltage goes from 13.6V to 12.6V
5. Switched on the air conditioner, the voltage goes from 13.6V to 13.4V
Referring to No.2 and No.3 above, is there a possibility for a wiring problem? It's because the voltage differences are too high. If yes, could you please give advice on what am I supposed to do to identify the problem. I've also check the parasitic drain and it doesn't happened.
Your opinions are greatly appreciated. Thanks.
