as the title says my car has some smoke coming out of the vents. it's not a lot, but it definitely is there.. I recently changed the head gasket so all the coolant had to be drained and for the first few miles i just filled it with regular tap water to see if there are any leaks. after being satisfied that there were none i changed to permanent fluid. now after some time i can see plumes of soft white smoke coming from the dash vents.. could it be the heater matrix had some tap water in it still and it didn't agree with the new anti-coolant??
also a couple more Qs if you please..
I definitely have to change the wishbone bush that dictates lateral movement of the front wheels (the front metal tube one that strongflex make) but i saw an ad for two whole wishbones on the fleabay and it would deffo be cost effective if i had to change the other bush and thingie that goes in the knuckle.. how do i determine if replacement is needed?
another Q I had is re. the white window guide thing that goes in the window rubber to keep it from falling forward into the door.. mine is broken and i have to use both hands to close the window, one on the switch and the other to push the actual glass back in its recess so it won't fall.. any idea where i can order a couple of these? or is there an easy fix for this problem?
Thanks in advance! oh i wanted to add that altough i just joined today I have been visiting this site regularly to help me with my DIY jobbies as all the work that is done on the car is executed by myself and my father (if possible nobody else touches my baby!) and we regularly turn to this site for various bits of info over the months, and for that, I thank you all.
