Cabrio1997
- Jul 10, 2016
- 16
- 5
Hi
My car went in to get a new head gasket done. 1.2 8V Fire.
I just went to see the mechanic and he showed me that that the gasket was burnt between cylinders 1-2 and 3-4.
He said this was because of wear on the block at cylinders 1 and 4 and that pressure was escaping, damaging the gasket and had allowed it to go at those points.
He gave me 2 options -
1) just put the head back on with a skim, new gasket and bolts and hope for the best - may last 1 month or 1 year.
2) Or alternatively, get the block skimmed which will cost $$$$.
The head gasket had only been done by the PO a few months ago, but he obviously did not skim the head or use new bolts. Also, it looks like there was not much antifreeze in it because of the amount of corrosion.
I am not too bothered about loss of performance because it is just a run around and I don't take it on motorways - but I don't really want it to break down on me!
What do you think my best option would be and any experience of how long it would be likely to last without skimming the block?
Cheers!
Cheers!
