Hi guys, my 1998 cabrio 1.2 16v failed mot earlier this week on emissions. Usual suspect is the lambda, so I replaced it today.
To double check if the lambda is ok, I read out the ECU and found two errors codes, electronic key and the lambda sensor.
As a Mac user, I had to use my old xp laptop, with very limited battery life, so after I had Multiecuscan working I didn't have much time left to try several things.
The strange thing is that Multiecuscan gives an error code, but in the parametres overview the status is closed loop, meaning the sensor is working, is this correct?
What am I missing here? Or what kind of extra test should I do with Multiscan?
