tompunto90
- Jan 17, 2011
- 2
- 1
erratic idle
Hi i am new to this forum. I have a 1994 punto 55 s 1.1 and i have been experiencing poor idle. When cold engine runs rough and sometimes it even stall. until it reaches optimum temperature and runs fine. After it reaches temperature it idles at high rpm and even experience erratic idling.
I suspected that the injector might be clogged so i put some redex in the tank. I also removed the iac valve and cleaned it but i accidentally started and run the engine with the iac out!! Should worry? should there be something between the plunger and throttle body?
Thanks for the help
Thanks for the help
