Thread Tools
Old 12-03-2015   #1
Luxembourg
Unhappy punto gt engine turns wont start.
Hi there.
i got a problem i want to share. my car, a PGT1, from 94 has some strange behavior. at first it cranked the engine but only started at second try(making a strange noise, like pushing a boot damper open). and some days ago it refused to start at all. strange thing was my ignition light went down after cranking the first time and did not came on till i turn the key to off again.
the car runs fine if i push the car to start it. but im not able to starting with key like a normal car. my blink test came out 1256.
guesses to help me please.
thanks a lot.
my punto is not as fast as my subbye but its scares me most.
Bruno Gomes is offline Reply With Quote Quote
Old 15-03-2015   #2
Its Adventure Time!
blu73's Avatar
Trader Rating: 2
blu73 has donated!
Skate Boarder Champion
Re: punto gt engine turns wont start.
code 1256 is RPM/crank sensor - N.B. for some ECUs, this may occur if the engine isn't running and may be ignored. The precise combination of factors is not 100% clear.
But check for fuel and spark, if you have neither then its likely the crank sensor is dead.
Finn - Panda 100HP - thread
Oberyn - Suzuki Ignis Sport - thread
Some previous cars: Alfa 159, Bravo HGT, Cinq 16v, Sei Turbo, Punto GT, Panda Mania 1242 mpi
blu73 is offline Reply With Quote Quote
Old 16-03-2015   #3
renaultvation has donated!
Before you change your crank sensor, check the contacts on the female side of the plug that the sensor connects to. I had a series of crank sensor failures which turned out to be poor contact in the plug. A quick adjustment of the contacts with a small screwdriver and all has been well since. Of course, it could still be a faulty sensor!
Thanks Bruno Gomes thanked for this post
renaultvation is offline Reply With Quote Quote
Old 17-03-2015   #4
Luxembourg
this next weekend i will spend some time around the car. i will check for fuel and spark and if conection failure, if not... dont know what to do.
my brother in law said it might be the ignition switch. but i think it works fine. whats really strage is that if i push the car down hill it will start and run normaly. thats why i think it might have spark and fuel.
but thanks for the reply, will come to you guys soon.
Old 18-03-2015   #5
Its Adventure Time!
blu73's Avatar
Trader Rating: 2
blu73 has donated!
well in that case i would suspect either a bad earth connection somewhere or something poor on the starting side, like battery not strong enough and voltage drops too much with load of the starter, or the starter is on way out and not spinning fast enough (does it turn over nice and fast when you try start with key?)
Old 25-03-2015   #6
Luxembourg
many thanks for all the help. it was in deed a groud conection, directly from the batery. i have a cut off switch there and when i check the resistance i found that i had some from the batery to the engine, just scraped all the dirt/rust from the conection, reconected it and voilą... it works again, starts at first, problem solved.
once more, thanks
Old 25-03-2015   #7
Its Adventure Time!
blu73's Avatar
Trader Rating: 2
blu73 has donated!
glad to hear its sorted
Thread Tools
1999 1.2 16v Punto Sporting won't start but engine turns. help. vallonchini Tech Talk 8 20-07-2012 17:00
(T) Punto turns over and sparks but wont start Help Please paulfiat Punto (Mk2/2b) 7 11-11-2011 00:13
(T) Fiat Punto turns over but wont start!! BMJay Punto (Mk2/2b) 19 14-10-2011 23:08
bravo wont start but turns over stevevac44 Lets Talk FIAT 2 06-01-2011 22:02
(T) 1.9 JTD turns but wont start gs1100hardtail Punto (Mk2/2b) 5 26-06-2009 20:50
