Technical No brake light (switch is ok)
chesh
Established member
Hi, I don't have any brake light.
Brake switch is ok, checked it on another car.
I don't get any voltage to the 2 wires that connects to the brake light switch.
All fuse are ok.
From a drawing I have, it says that one of the 2 wires (blue-red) is connected to pin number 14 on the D connector:
I checked the wire but there is no voltage (ignition is on)
I checked pin number 13 that should be the interior light-reverse and rear lights, those are working but I can't get any voltage either. weird.
When I connect the yellow wire (from pin 13) to the blue-red on pin 14, the interior light is on (without pressing the indicator) and I get 12V from both of them.
I can see a disconnected purple wire coming from pin 10:
Tried to connect it back but it won't effect anything.
Don't know what is this wire for.
Any help?
