FIAT Auto Specialist Team
Thread Tools
Old 09-08-2014   #1
Israel
RPM stays high only when I release the clutch
Another issue with the cabrio,
Changed the clutch few weeks ago but problem was before.
It's not always, mostly when the car is after a long drive.
RPM stays on 2000 when I change gears, until I release the clutch at it's point.
Problem is on neutral gear also, RPM stays high too until I brake almost completely, then it falls to the right RPM.
I susspect the brake master cylinder, hose doesn't look too good although I changed the bit that goes to the manifold.
Could it be the direction?
chesh is offline Reply With Quote Quote
Old 09-08-2014   #2
Trader Rating: 5
fingers99 has donated!
Re: RPM stays high only when I release the clutch
Could be. Air leak into manifold ("vacuum air leak") = high idle speed.
M12 fund 20
fingers99 is offline Reply With Quote Quote
Thread Tools
(T) High RPM at idle Henne100HP Panda 25 18-07-2017 16:24
High RPM - too high? chiggy321 Tech Talk 2 06-02-2012 14:39
(T) High RPM while driving MKoers Cinquecento / Seicento 6 21-05-2011 13:04
(T) Injector cleaner,high rpm? foggy89 Cinquecento / Seicento 12 01-03-2011 16:44
(T) X1/9 stalls low rpm - runs fine high rpm erisajd X1/9 6 18-01-2005 03:06
