Another issue with the cabrio,
Changed the clutch few weeks ago but problem was before.
It's not always, mostly when the car is after a long drive.
RPM stays on 2000 when I change gears, until I release the clutch at it's point.
Problem is on neutral gear also, RPM stays high too until I brake almost completely, then it falls to the right RPM.
I susspect the brake master cylinder, hose doesn't look too good although I changed the bit that goes to the manifold.
Could it be the direction?
