I have a 1997 Punto Mk1 75 SX. Lately I am facing a problem which is whenever I put the key inside the ignition key hole, it seems the key hole is stuck, it is not rolling the key. Only after 4-5 attempts that I am able to turn on the ignition. Could you all kindly tell me what should I do? I have all the necessary keys with me, red, blue, brown...
I am from Finland. A mechanic here told me that there is a scrap yard here, I need to go there and they will fix it. I don't know how much will it cost. He said that if I go to the authorized dealer here it will cost me a big time. I hope my ecu is working fine. So should I need to change the whole package or just the ignition keyhole?
Could the experts here kindly help me and reply? Thanking you all in advance for your time and replies.
Regards,
D
Regards,
D
