(CZ)enda
Established member
- Aug 15, 2005
- 822
- 171
As stated above, the engine runs on 3 cylinders and it is No. 1 cylinder (timing belt side of the engine) which does not fire properly. I changed the supposedly obvious culprits (new spark plugs/HT leads) to no avail.
BUT the best part of the story is that if I remove the lead from the non-firing cylinder while the spark plug is in the engine, there is a healthy spark (say, 5 cm) from the end of the HT lead to the spark plug/engine block. And when I remove the spark plug and put it into the HT lead and touch the engine, the spark plug works OK. The firing sequence is the same as it was before.
I must admit I am at my wit´s end right now.
