Old 29-11-2013   #1
Egr problems
Hi there can I fit a vauxhall Astra egr to my Punto mk 1 elx 90 1.6 as they look the same ?
Elxpunto90 is offline Reply With Quote Quote
Old 29-11-2013   #2
dave's Avatar
Trader Rating: 10
dave has donated!
Re: Egr problems
THIS IS WHY TORIES CANT CLAIM HINDSIGHT! https://www.youtube.com/watch?v=bQDPQ8bz7cU
Old 29-11-2013   #3
Trader Rating: 5
fingers99 has donated!
Re: Egr problems
Can't speak for the Astra, but AFAIK, the Punto 90 was never fitted with an EGR.
Pic would help!
M12 fund 20
fingers99 is offline Reply With Quote Quote
Old 29-11-2013   #4
Re: Egr problems
Name:	ImageUploadedByFIAT Forum1385734554.869858.jpg
ID:	127146Click image for larger version
Name:	ImageUploadedByFIAT Forum1385734567.633615.jpg
ID:	127147Click image for larger version
Name:	ImageUploadedByFIAT Forum1385734580.285298.jpg
Old 29-11-2013   #5
Its Adventure Time!
blu73's Avatar
Trader Rating: 2
blu73 has donated!
Skate Boarder Champion
Re: Egr problems
so have you managed to do a blink test then? Is this what code it gave you?? Just curious.
I would try taking yours off and cleaning it, see if it works, they can get clogged as very sooty. Unless its the electrical part that has failed.
blu73 is offline Reply With Quote Quote
Old 29-11-2013   #6
Trader Rating: 5
Re: Egr problems
Well, that's a turn up. The Poles have another solution.
No idea if it works, why FIAT fitted such a silly thing, what points you in the direction of the EGR, etc.
M12 fund 20
Old 29-11-2013   #7
Busy rebuilding pand'a
oldhammer's Avatar
oldhammer has donated!
Re: Egr problems
just buy tin of coke from shop drink it and use can for egr blank
easy to make..
oldhammer is offline Reply With Quote Quote
Old 29-11-2013   #8
dave's Avatar
Trader Rating: 10
dave has donated!
Re: Egr problems
well well learn something new every day
Old 29-11-2013   #9
Its Adventure Time!
blu73's Avatar
Trader Rating: 2
blu73 has donated!
Re: Egr problems
yep, i blanked off a egr on a corsa b 1.2 16v the other day. Blank came from a polish guy for that too as it happens. Not spoken to the owner yet to ask if it made noticeable difference but if forums are to be believed they go noticeably better. She has constant eml on that though cause it don't work, causes the tb to clog up eventually. car ain't worth anything so thought we'd try one of these blanks to stop tb clogging.
contemplating dpf removal and egr blank on my alfa atm. Just cause dpf's are a silly invention but the egr apparently clogs on them without the dpf.
Old 30-11-2013   #10
Re: Egr problems
Not done blink test yet but have replaced every sensor apart from egr and air temp sensor or air filter pipe
Old 30-11-2013   #11
Re: Egr problems
I have cleaned egr 3 times still no different is the piston inside supposed to be loose going in and out
Old 30-11-2013   #12
Its Adventure Time!
blu73's Avatar
Trader Rating: 2
blu73 has donated!
Re: Egr problems
yeah it should. They usually have a spring holding it shut but you should be able to move it freely and easily with a screwdriver or similar and it then close shut on its own after.. Never had one off these engines - but you made me curious as to whether my GT has one now lol.
Old 01-12-2013   #13
Re: Egr problems
Name:	ImageUploadedByFIAT Forum1385888032.786205.jpg
ID:	127209Click image for larger version
Name:	ImageUploadedByFIAT Forum1385888041.910435.jpg
ID:	127210Click image for larger version
Name:	ImageUploadedByFIAT Forum1385888053.552237.jpg
This is where it would be if it helps
Old 01-12-2013   #14
Its Adventure Time!
blu73's Avatar
Trader Rating: 2
blu73 has donated!
Re: Egr problems
i very much doubt i will even look at my punto until spring now tbh. Doesn't look like its gonna sell before xmas and then the mot will have run out. So i think i shall be keeping it for a bit longer now.
Old 15-12-2013   #15
Re: Egr problems
I've tried a blanking plate and it sounds awfull with I pinking noise so scrapped that idea going to get a vauxhall egr for it
(T) Problems with egr dpeharda Bravo 2 16-05-2013 19:02
(G) EML comes on - EGR problems? sludgeguts Doblo 15 07-05-2013 20:45
(T) Blanking EGR may cause some problems!! midayt47 Multipla 13 31-05-2011 00:06
(T) egr problems garymoore Punto (Mk2/2b) 0 10-04-2009 13:27
(T) Grande Punto EGR Problems kevinb3510 Grande Punto 6 05-01-2009 22:39
