dumbledore
Member
- Jul 4, 2010
- 745
- 144
Here is some question I got from an earlier thread from User: portland bill
Oil leak is possibly the easiest, look for the highest point of the leak. If you can't find it, clean everything and look at it regularly until the source is apparent.
The leak apears to be coming from the top of gearbox and covers the whole of the top. I can only assume it comes from the selector cover that I had to remove because I could not change gears. Removed the gear selector rod from the wrong place and selector stopped working hence the cover needed to come off. There does not seem to be a gasket between the selector cover and gearbox so I put it back on the same way as when I took it off. May I should have put some gasket sealent? There is no mention of selector removal/fitting in the Heynes manual so don't know for sure how this is done.
The top of the gearbox became wet during the clutch change because I had to replace the clutch slave cylinder, which meant I had to drop quite a bit of brake fluid on the gearbox, but I suspect the brake build would have evaporated by now as the gearbox still looks wet at the top.
As the leak is not that significant I shall monitor things to confirm the source of leak before I make a move to try to fix this.
