Not sure how or what I did, but I managed to connect to the ECU and logged this data:
(The software didn't recognize my cars make or model, but did in a previous attempt!!).
2014-02-01 11:49:12
IAW Scan 2 [v0.81]
CONNECTED TO:
Unknown
Magneti-Marelli IAW-6F/16F SPI
PARAMETERS:
Engine Speed: 1008 RPM
Injection Duration: 0.94 ms
Ignition Advance: 10.00 °
Manifold Absolute Pressure: 376 hPa
Air Temperature: 15 °C
Water Temperature: 70 °C
Throttle Opening Angle: 8.89 °
Battery Voltage: 13.63 V
Lambda Probe Correction: 1.00
Idle Stepper Motor Position: 27 steps
Idle Stepper Integral Gain: -31
Idle Stepper Proportional Gain: -4
Trimmer Position: 0 steps
Autocalibration Correction: 0
Autocalibration Correction with A/C: 4096
Idle Engine Speed: 888 RPM
Idle Engine Speed Offset: 0 RPM
Stepper Correction (Delta): 111
Stepper Correction from FLT: 0
AC Offset Parameter (min. load, EVAP off): 0
AC Offset Parameter (min. load, EVAP on): 0
AC Offset Parameter (min. load): 0
AC Gain Parameter (med. load): 0
Engine Running: YES
Sensor Signals OK: YES
Throttle at Min/Max: YES
Lambda Sensor in Closed Loop: NO
Air Conditioner ON: NO
Mixture AutoCalibration ENABLED: YES
Stepper AutoCalibration ENABLED: YES
Power Latch Line OK: YES
haven't a clue what this all means, but if there's anyone out there who can point me in the right direction i would be eternally grateful.
