Old 04-06-2002   #1
Punto Clutch Problem
Hi
I have a Punto 75 ELX and for the past week it has been very difficult to push the clutch pedal to the floor. At about half way down, there is a clicking/scratching noise that appears to come from the clutch itself. (possibly a spring?) I have checked the slave cylinder and that's ok.
I have actually used WD40 on the lever that releases the clutch (the bit that the slave cylinder pushes) and the problem disappears for a day or so.
Is this just a lubrication problem, or is the clutch on its way out?
Any advice would be great ..
Léon
P.S. If it is the clutch - what's the average price I should be paying?
leon.judge@ntlworld.com
leon_judge is offline Reply With Quote Quote
Old 30-08-2002   #2
I have the same problem with my mk1 punto sporting, it does sound like a spring, cant figure out the bitchin problem either. have a similar noise when i move the gear lever left-right when it's in neutral.
New clutch is max £80 plus labour of about £50-100 depending on where u go.
peace.
squiggle squiggle
aleko is offline Reply With Quote Quote
Old 03-09-2002   #3
<font face='Tahoma'></font id='Tahoma'>
My clutch went like that, a week later I started it after work and couldn't select any gears... The clutch was f**ked!
I paid £240 @ Mr Clutch to bet a Borg Warner fitted, it was only £50 more than a standard clutch and worth every penny.
PS My car 1996 1.6 Punto Sporting
dickie is offline Reply With Quote Quote
Old 09-04-2006   #4
Re: Punto Clutch Problem
look out for those 1.6 sportings mk 1 clutches, as mine did the exact same thing as dickies
pain in the arse
i got my clutch for £180 so depends where u go
g1 6rum
G1 6RUM is offline Reply With Quote Quote
Old 09-04-2006   #5
Quote Originally Posted by leon_judge
Hi
Léon
I have read on this group some who have said they have replaced the clutch only to find out it was the slave cylinder that was clicking! - anyway you have tried that and found your clutch slave cylinder to be OK so then it must point to the clutch then I suppose. Just out of curiosity how do you check a clutch slave cylinder? - do you have to take it off the engine?
Cheers,
Andy.
andyr is offline Reply With Quote Quote
Old 05-12-2007   #6
I have a 1.1 55s punto and my clutch was making the same noises and was really hard to get into gear. i had to replace my clutch cost me £240 for a standard clutch to be fitted.
danielleg is offline Reply With Quote Quote
Old 08-12-2007   #7
Brendan W has donated!
Ireland
Hi Leon,
Had the same problem with the clutch , 1.2 8V 2001 42000mi.
WD40 on the release arm seemed to make a huge improvement and I was considering not replacing the clutch but there was still a faint whirring noise from the bellhousing area. Anyway common sense prevailed and when the old parts came out I was amazed the car was still running so bad was the damage to the pressure plate springs and the release bearing.
My tuppenceworth is fit a new clutch kit before the whole thing goes to flitters and costs an arm and a leg to sort.
Safe motoring
Brendan W is offline Reply With Quote Quote
Old 08-12-2007   #8
look at the date, this problem was posted in April 2006
jaybee is offline Reply With Quote Quote
Old 11-12-2011   #9
Question Re: Punto Clutch Problem
hi there a couple of days ago my clutch failed i think so i had a new clutch kit put in by a freind.. it drove result and then it stoped again and wouldnt drive . any ideas ??
chris12 is offline Reply With Quote Quote
Old 11-12-2011   #10
Trader Rating: 5
fingers99 has donated!
More details please on "it wouldn't drive". What was happening?
M12 fund £20
fingers99 is offline Reply With Quote Quote
(T) Solution to Punto 75 mk1 Engine Problem Tziallas Punto (Mk1) 8 10-09-2010 08:17
(T) Help clutch problem!! Picture inside! Xplode Cinquecento / Seicento 16 02-12-2009 23:35
(T) Strange Clutch problem Julio_Scorchio Cinquecento / Seicento 21 16-11-2008 02:02
(T) Funny Clutch problem Matts Dad Punto (Mk1) 2 18-11-2003 23:49
(T) Punto 75 SX '98 battery & electronic check problem zokipet Punto (Mk1) 3 22-02-2003 03:37
