Technical charging my battery
Re: want to charge my battery
cheers mate i dont use the car as i go 4 my test next week so cant drive it and get more charge in it just go in the car park in it but wot every ones saying its not a nuff and im so sorry about putting the same threads on new 2 all this and cars lol
my jump starter as 36 hours ov charge wud my battery charge by useing the attachment to go in the ciggy lighter wud that do it
I think Dave knows a lot more about Thermodynamics than you give him credit for.
It's an old, old joke. A few years ago we more or less chased Dave out of the Cento section for a faux pas involving the Laws of Thermodynamics.
But then, I know bugger all about rabbits (apart from that they're good to eat and can't outrun a lurcher...........)
That's using a battery to charge a battery. Unless your jumper specifically says that it will charge a battery, forget it (the cheap ones won't).
you could trickle charge through the cig lighter with one of them solar panels i have seen in the shops... no idea how long it will take from flat and as i mentioned before overcharging batteries is bad and a solar panel will not stop charging once its fully charged..
Battery charger is not alot of money just go buy one.
Unless the Solar Panel has a sensor switch of some kind that tells you its charged?
Hardly any sun at the moment so a solar panel won't do it. A wind turbine on the other hand may do the job. As you have a jump starter just use it whenever you want to start the car until you can have a go and charge the battery with a good drive.
You dont need much sun for a Solar Panel, it works on light that comes from the sun, we call this daylight. It is better with lots of sun and facing south.
couldn't say never really looked at one, just seen them in halfords and the like - i know Eklipze3k has one but again never looked at it.
I use a mouse strapped to a small wheel near the battery with a small alternator sending a charge to the battery, unfortunately the cold weather means I have to replace the mouse every night
have you not seen slow down and speed signs that run on solar? they don't stop working in the winter
If you look careful at them they have a wind turbine too. 7 hour of daylight does bugger all. Unless ofcourse you are prepared to put a roof solar panel.
Here is one, I took the other day outside my house!!!
