Hello everyone ..
I have a punto MK1 and the hand brake light on the dashboard not working at all.
I checked the bulb with a multimeter, but it was O.K, also switched between bulbs but it didn't help.
Unplugged and replugged the 4 connectors on the instrument panel, but the song remains the same.
I checked the hand brake switch (which is actually just a tin with a spring), but it was clean and working correctly.
As far as I know, when I pull the hand brake, the switch connects to the vehicle body and gives ground, so I took it up so it won't connect to ground, but the bulb still not lit.
Where this wire leads to? I saw it goes under the carpet, to the electrical harness and into the insulation of the firewall.
Is the wire leads directly to the dashboard or to the fuse box / relay?
Is the bulb should turn on like the battery or oil light when I turn the switch to MAR?
Have a joyful day
Any help would be appreciated.
Have a joyful day
